04-07-2007, 11:58 AM | #1 |
Drive shaft swap....
So,my 71 didnt have the front driveshaft when I got it and I have a complete driveshaft from another truck and was wondering if it will work on the 71.The truck the d-shaft came off of was a 69 4wd that had a Rockwell T case.And I want it to connect to my 205....So is everything (CV joints,ect) the same,will it all interchange?Are they the same length?
04-07-2007, 08:55 PM | #2 |
Aluminum slot wheels rule...
Re: Drive shaft swap....
The Rockwell shaft is too short. You'll need to get it re-tubed 2 inches longer if you're going to use it with the 205. Other than that, they are the same and will work.
04-07-2007, 08:57 PM | #3 |
Hmmm,probably would have to lenghthen it with the lift kit anyways......
