04-07-2007, 07:25 PM | #1 |
Heat Riser Gasket
Well I am stuck with a heat riser and the time has come to put the ram horns back on. I got the passenger side on but now I am stuck at the drivers side. The gasket has a triangle bolt pattern.The opening is almost 2 1/4 on the heat riser but all of the gaskets that I have asked about have a 2 1/2 opening. That seems to big to me. Does anyone know if this is the correct gasket size?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
04-07-2007, 08:01 PM | #2 |
Re: Heat Riser Gasket
pictures we need pictures
04-07-2007, 08:04 PM | #3 |
Born Psycho
as long as the gasket will fit the bolt pattern you should be fine, just make sure it has the steel ring in the center and both surfaces are clean. i can get you the correct one monday when i go back to work if you don't find the right one before then. p.m. me if you need one.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-07-2007, 08:48 PM | #4 |
Heres the pic..
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 Last edited by skokie; 04-07-2007 at 08:51 PM. |
04-07-2007, 08:49 PM | #5 |
The gasket has a 2 1/2 opening and the heat riser itself it almost 2 1/4.
04-07-2007, 10:05 PM | #6 |
Ttt
