Old 04-07-2007, 05:07 PM   #1
corkscrew
How does the brake light swith hook up and work??
im a rookie...thanks for the help
corkscrew is offline   Reply With Quote
Old 04-07-2007, 06:26 PM   #2
corkscrew
Re: How does the brake light swith hook up and work??
just bumpin
Old 04-07-2007, 06:58 PM   #3
rage'nrat638
rage'nrat638's Avatar
heres the switch just mounts to a bracket under the dash and bumps into the brake pedal.
very simple little switch..
heres a picture
rage'nrat638 is offline   Reply With Quote
Old 04-07-2007, 07:36 PM   #4
corkscrew
so where does it just hooks up one for the power one for the ground or what??
Old 04-07-2007, 08:10 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
There is a plug for it above the brake pedal. Should be plastic; it plugs into the bottom of the switch and snaps in place.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-07-2007, 08:25 PM   #6
dave2953
dave2953's Avatar
Here is a pic. The brake pedal rod is in the way, but hopefully you get the general idea. Hope this helps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 04-07-2007, 08:27 PM   #7
centsless
sufficiently talented fool
centsless's Avatar
One of the wires is a power wire, the other goes to the brakelights.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-07-2007, 08:32 PM   #8
corkscrew
well im off to see if it works...if the signal works the brake lights should work too eh?
Old 04-07-2007, 08:36 PM   #9
centsless
centsless's Avatar
No. The signals could work and you could still have no brakelights. The wire that goes to the brakelights goes thru the turn signal switch. Check for power on the one wire at the switch. Then check the other. It should have power only with the pedal depressed. If they are OK, then you need to check the turn signal switch.
2003 Suburban
1981 Corvette
Old 04-07-2007, 08:55 PM   #10
corkscrew
yeah the lights dont work i plugged in orange to orange wires and white to white and it aint workin...
Old 04-08-2007, 02:11 AM   #11
corkscrew
well it turns out there was no power to the line which goes underneath the floormat which surprised me...anyone now there these wires are supposed to go?? like from the switch?
