Old 04-08-2007, 04:28 AM   #1
DOOBZ
Airline and heat?
I am wondering how close an DOT airline can be to my exhaust, in one area it will be 4" from the exhaust pipe. Is that to close or will the airline take the heat? Thanks, Mike
85 short, bags,4-link and sway bars
DOOBZ is offline   Reply With Quote
Old 04-08-2007, 11:12 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Airline and heat?
No, it will not take the heat. I have had to lines blow and both times it was from being to close to a heat source. It "might" be safe if you put a piece of rubber hose over it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-08-2007, 11:18 PM   #3
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
what is the recommended space to keep between air lines and exhaust?
IvelDesigns is offline   Reply With Quote
Old 04-09-2007, 09:43 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
My suggestion would be "nowhere near" the exhaust. The last line I had blow was because the exhaust pipe pulled out of the catalytic converter. It was blowing hot air toward the line and caused it to blow.
Anything that can be done to prevent routing airline away from the exhaust is money in the bank.
Articles-
"Refining Sierra"
Old 04-09-2007, 09:50 AM   #5
SCOTI
SCOTI's Avatar
If it has to be routed near your exhaust, create some type of heat shield that's mounted solid. After the heat shield, put the lines in a temp resistant 'sleeve', similar to what is used on spark plug boots.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-09-2007, 11:35 AM   #6
bedsled71
bedsled71's Avatar
i have mine somewhat near my exaust but i slid a bigger piece of airline over the sections near the heat...
bedsled71 is offline   Reply With Quote
Old 04-09-2007, 05:40 PM   #7
DOOBZ
Thanks for all the advice! It also gets me wondering how everyone is routing their airline? Im trying to keep them inside the frame rail but when i get to the front i cross paths with my exhaust-which also gets me wondering- is it advisable to run airlines on the outside of the frame towards the top? Looks like the lines would be mostly out of harms way. Whats your thinkin? Thanks Mike
Old 04-09-2007, 06:25 PM   #8
jimmydean
jimmydean's Avatar
My lines run along the inside and are at least a foot away from my exhaust just about everywhere. The one spot that crosses over is attached to the crossmember that holds my carrier bearing and I ran them as close to the top of the as I could.
<edit> my exhaust is nothing more than straight pipes off the headers down either side of the drive line and end just past the trailing arm crossmember. Very ghetto, but functional until I get it redone.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
