Old 04-08-2007, 09:28 PM   #1
bad72c10
bad72c10's Avatar
TH350 to 700R4 Driveshaft
Hey guys, I have a TH350 with a 9" tailshaft in the truck now, so I should be able to reuse the driveshaft for the 700r4 with no modifications, correct?
Also, when I look up a transmission mount, it has three holes, yet the crossmember only has two, how does that work?
And lastly, does anyone know where I can get just a single speedo gear?? BTO only sells a $52.00 complete set
Thanks for your help, Justin
'72 C/10 SWB 355/ broken TH350 and 3.07s Soon to be 355/700r4 and 3.73s
bad72c10 is offline   Reply With Quote
Old 04-08-2007, 09:43 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: TH350 to 700R4 Driveshaft
The TCI website shows them to be nearly identical in length. Your trans. is 30 11/16 and the 700R4 is 30 3/4, so you should be able to use your current driveshaft. I'm not sure about the mount or the speedo. I'm sure someone else will chime in and let you know.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-08-2007, 09:49 PM   #3
lamar
lamar's Avatar
I went from Turbo 350 to 700R4 and I had to have my drive shaft cut and rebalanced. Also had to relocate the trans mount.
72 C-10
lamar is offline   Reply With Quote
Old 04-08-2007, 11:08 PM   #4
Mixup
I had the 9" tailshaft 350 and the shaft worked fine. The speedo worked to just had to change the gears to match the tire size and rear ratio. Crossmember has to move back to match the 700r4 mount.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 04-08-2007, 11:49 PM   #5
bad72c10
bad72c10's Avatar
Thanks Mixup, I was sure it would work, but it is good to hear from someone who has done it. I knew the X-member had to move back, but the holes where you bolt the tranny mount to the x-member has 2 holes, yet the mounts that I see have 3 holes for bolts. does it work anyway?
Old 04-08-2007, 11:57 PM   #6
cooters
just go to a tranny shop, the mounts come in 1 ,2,bolt holes or even a stud. Get the one you need from the tranny shop is usually the cheapest and they should stock them all.
cooters is offline   Reply With Quote
Old 04-09-2007, 05:27 PM   #7
Mixup
Mine has the 2 bolts that hold the mount to the trans and 2 bolts from the crossmember to the mount. You might have to get a different mount.
1969 Z28 engine
Turbo 350
Old 04-09-2007, 05:45 PM   #8
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
You should be able to buy the speedo gear from a GM dealer individually.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
