Junior Member
67 chevy k20 spindles
i am looking for a set of spindles for a dana 44 closed knuckle front end. If i cant find then will other spindles work?
Junior Member
Re: 67 chevy k20 spindles
oh yea the hubs are external with the knob made out of metal with the cover held on by 6 3/8 bolts 4 inches long
I believe you can use up to`69,the last year for closed knuckles.
I may have some used ones, I can check and see
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
![]() Join Date: Aug 2004
I have some for sure, is it just the spindles that you need or more? I have the drums and more here, and can let the stuff go reasonably. Let me know if you need pictures.
Junior Member
the front spindles is all i need right now but you know how that goes. Im fixing up truck that has been setting for 8 years in a field
Junior Member
after futher checking it out, i need the small springs that go behind the lockout assembly. some pics would be nice. thanks
Pictures as requested. These are off of a 67 k20 and are in very good condition. Leyt me know if I can be of anymore help. JOHN
Junior Member
john pm me .I am interested in the spindles. Thanks
You`d do good to buy up these parts.They`re all obsolete,might not be around next time.Just an observation from a fellow vintage 4wd nut.
Junior Member
john i'll take all of it if that is what you want to do. also im looking for a rear brake drum that is off a eaton that has 12" brakes 2 inches wide
Junior Member
hey special K, thanks for getting that through my thick pumkin
are 1/2 ton spindles the same?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
