hei question
I got a factory hei pigtail I know how it connects to the dizzy but what did this other end connect to? Never seen a conector like that.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Re: hei question
Snip snip. Its made for a newer vehicle that had an HEI from the factory. You will have to cut the end off & depending on how you convert the wire on your fuse box will determine the wire end you use...
Re: hei question
hey pink
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
member #16
![]() Join Date: Dec 1999
Re: hei question
If the wire is long enough it will plug in the firewall block where the resister wire is now. Looks like the same terminal end.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Re: hei question
I think now it is pluged into the fuse block on the ING with a female spade.
