Old 04-14-2007, 12:57 AM   #1
SCOTI
SCOTI's Avatar
Coil Suspension: Stainless Lowering Blocks
I made my own 2" lowering blocks from some scrap 2x2x.250" stainless steel that was heading to the recycler. While digging through the bin, I also found some other small lengths of 2x2x.187" (3/16") stainless.
Since I'm no mechanical/structural engineer, I was curious if the .187" would work for lowering blocks?
I use schedule 40 tubing as 'inserts' within the block itself so the u-bolts won't crush the tubing. I would guess w/the .250" tubing, inserts aren't needed; but it's not a bad idea to use them w/the .187" wall tubing.
What do you think?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-14-2007, 06:08 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: Coil Suspension: Stainless Lowering Blocks
Well, the C5/C6 Vette frames are hydro formed and I can tell you they are less than 3/16" They use tube "inserts" as you describe and hold up just fine. Hope that helps.
Frizzle Fry is offline   Reply With Quote
Old 04-16-2007, 02:21 AM   #3
Rollie396
someday it will be done!
Rollie396's Avatar
Go with the inserts for whatever you decide.Worth the piece of mind for time it takes.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 04-19-2007, 06:25 PM   #4
XXL
Señor Member
XXL's Avatar
Originally Posted by SCOTI View Post
I made my own 2" lowering blocks from some scrap 2x2x.250" stainless steel...
I would have used a clear hickory or oak, but I think you'll be alright with the SS.
XXL is offline   Reply With Quote
