Old 04-14-2007, 02:18 PM   #1
mnky30
mnky30's Avatar
3 speeds trans
i have a 1960 with 283 v8 and a 3 speed, trans looks real small to handle some more power is the 3 spped trans really tough
mnky30 is offline   Reply With Quote
Old 04-14-2007, 04:03 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: 3 speeds trans
I'll let you know...
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-14-2007, 06:57 PM   #3
desertrat
desertrat's Avatar
Re: 3 speeds trans
It's small because there are only 3 gears. It can handle a few more horses.
Just don't try reverse burnouts ( I did when I was 16 in my '62 )
Also don't speed shift if it is still a column shifter. ( another stupid mistake a 16 yr. old makes)
desertrat is offline   Reply With Quote
Old 04-14-2007, 07:28 PM   #4
mnky30
mnky30's Avatar
Re: 3 speeds trans
thanks for the info
Old 04-14-2007, 07:58 PM   #5
factorystock
factorystock's Avatar
Re: 3 speeds trans
The strength isn't the problem, it the fact that first gear is not synchronized. You must make a complete stop to put the transmission into first gear or you will hear a grinding sound.
factorystock is offline   Reply With Quote
Old 04-14-2007, 08:13 PM   #6
SkylineNXS
SkylineNXS's Avatar
Re: 3 speeds trans
is this 1st gear not syncrinized in turbo 35o's also? I know its an auto, but if i dont make a cmplete stop, the truck doesnt accelerate as well, like its in second instead of first.....(sry for the highjack)
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 04-14-2007, 09:20 PM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: 3 speeds trans
Sounds like you have a kick-down linkage problem....disconnected or mis-adjusted.
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-15-2007, 07:03 AM   #8
jwart
Re: 3 speeds trans
have 327 build 4000m. ago. 450 lift cam & 850cfm quadjet off big block buick. i bang gears pretty hard with it. got 4:11 rearend & can lay 50yrd of rubber & make it squell thru 3rd. put indy floor shift on it. even fit good with bench. has held up thru 2 sets of tires. have it going into my shop this week for front disc brakes/thanks to a 78 donor truck. drums just don't cut it anymore jw
straight pipes save lives!
jwart is offline   Reply With Quote
