Old 04-14-2007, 04:52 PM   #1
llama
Attaching firewall insulation
I'M installing new firewall insulation pad and the plastic push pins seem to big. They do not want to go in. Is there a special tool to drive them in? Whats the trick?
llama is offline   Reply With Quote
Old 04-14-2007, 05:21 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Attaching firewall insulation
I have not done this on our trucks but I have done it. make sure the inner dia. of the pin is not bigger than the hole. Then I use the top of a hammer (where the handle come out the top) not the head unless you have a tight spot
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-14-2007, 06:04 PM   #3
byrd
Union Electrician
byrd's Avatar
x2 on the hammer, although I would use something closer to the actual diameter(maybe 3/8" socket extention) of the plug and tap on it using the hammer to drive the plug in.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-14-2007, 08:52 PM   #4
neonlarry
neonlarry's Avatar
Also a little liquid soap or radiator hose grease works wonders too.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-15-2007, 08:36 AM   #5
llama
thanks guys will give it another try today
Old 04-15-2007, 06:35 PM   #6
72swbcamo
Active Member
I'm pretty sure that I saw an installation tool for the firewall insulation holders. I think it was in a Truck Shop catalog. It was a simple step shaft. Wasn't very expensive if I recall.
72swbcamo is offline   Reply With Quote
