pitman arm location
guys, how far up the steering box shaft is the pitman arm supposed to go up? I'm wondering because I have a lot of spline left on mine. It looks like the pitman arm can slide up about 3/4 of an inch more. If I can do this, my tie-rod clearance issues might be solved. Here is a pic of what I'm talking about. Can you check to see where yours is at?
someday it will be done!
Re: pitman arm location
mine looks very similar to yours.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
yea I just read a very good thread about this. That splined shaft is tapered, so the pitman arm only can go so far up. So I dont think I would be able to get it up any higher.
![]() Join Date: Mar 2006
Well that makes me feel better because mine is the same way. Thanks for the thread.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
![]() Join Date: Mar 2003
As long as the nut is torqued and the threads pass all the way thru the nut with the lock wahser in place, everything should be good
it's a tapered hole on a tapered shaft ... much like a ball joint. once the nut is fully torqued, the tapers are seated.
