Old 04-16-2007, 04:37 PM   #1
Texas1971
New build gas to carb flow question
Finally got everything in and connected since starting with a bare engine compartment last year. This should have been the easiest part but now I cant get the fuel pump (new) to push gas to the carb. 327 sb to edelbrock. used an electric pump to get the flow started from the tank. Any thoughts about getting the flow going is appreciated.
Texas1971 is offline   Reply With Quote
Old 04-16-2007, 05:29 PM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: New build gas to carb flow question
Fill the float bowls with fuel and you should be fine after start up. It does not take long for the pump to put fuel to the carb if it is already to the pump. I woulds say 1 or 2 revolutions of the engine really. If the engine is new make sure to break in the cam according to manufacters specifacations. Good luck lighting fire to the new powerplant it's a woderful feeling after the work is done
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
