Old 04-16-2007, 06:18 PM   #1
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Unhappy My truck is no longer with me...
... that's because it's actually at the Chevy dealership right now getting WARRANTY work done. That's right, I said WARRANTY!
In the past week, the truck has started blowing a puff of smoke on startup after it's been sitting for a while. It's also half a quart low. This past saturday, I took the plugs out, and it turns out cylinder 2 plug is covered in oil. I replaced the plugs, ran it 100 miles, pulled the plugs again, and the same thing. I figured it was time to take it in.
After about 30 minutes of arguing with a moron service adviser about the meaning of the word WARRANTY, he finally agreed not to charge me for the diagnostic. You see, I have a GMPP crate motor with about 2000 miles on it. I got it from Jegs, but it has a factory warranty with GM. The ****ty part, is that because I installed it myself, they won't warranty labor, only parts. So if I had, say, a bad piston ring in number 2, they would hand me a $5.00 set of rings for it, and say good luck! I sure hope it's something like a cracked head, so I can still replace it myself fairly easily.
xtreme80 is offline   Reply With Quote
Old 04-16-2007, 06:28 PM   #2
71SWBChevy
71SWBChevy's Avatar
Re: My truck is no longer with me...
That sucks man, hope its something that isn't to hard to fix.
That is BS that they only warranty parts not labor if you do the install, how many people can even AFFORD the rates that a dealer would charge for an install!
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 04-16-2007, 06:34 PM   #3
xtreme80
xtreme80's Avatar
Exactly! I mean I had to pay the sky high price just to have the warranty on the engine... I can't imagine what my total cost would be if I had to have them install it.
Besides, what the hell does my installation have to do with an engine burning oil?!
Old 04-16-2007, 06:44 PM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
Thats a standard GM parts warranty. They only cover labor if a GM dealer does the install. Otherwise they only warranty the part that failed. It's got nothing to do with you installing the engine for the oil burning. It sucks that an engine with 2000 miles is burning oil.
If it were me I would have spent the time before taking it to the dealer and made sure I had a decent understanding of what was wrong. Some time with a compression tester and a leakdown tester would have at least told you if the oily plug cylinder was loosing compression through the rings or if you had a leaking valve that might be letting oil get in.
Good luck though!
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-16-2007, 06:45 PM   #5
garysouthlake
'lox'
garysouthlake's Avatar
Don't give up yet. Take your case to the dealer General manager. If he can't help, ask for the Regional Chevrolet Manager. Be prepared with a 'resume' or 'qualifications recap' to show/prove that you know how to install engines. If the Regional manager can't help, ask him/her who you can contact. (The squeaky wheel gets the grease). Even if you don't get anything, think of all the nice people you'll meet !!!
garysouthlake is offline   Reply With Quote
Old 04-16-2007, 06:48 PM   #6
xtreme80
xtreme80's Avatar
Zoomad75, I was going to go ahead and run a compression test on it, but my compression tester wasn't working right. I think the last guy I let borrow it broke the guage. Damn kids...
I'm not too worried. I could have spent the time to figure out what it was, but what's the point when I can have GM do it for free anyways.
And gary, I have plenty of ways to show them how qualified we were to install it, seeing as I work in a shop myself, and my dad, who helped with the project, was an ASE certified master technician for 30 years. I'll have no problem proving those!
Old 04-16-2007, 07:06 PM   #7
68Stepbed
68Stepbed's Avatar
What engine do you have? The only GM engine with a parts and labor warranty is the stock 260hp GMGoodwrench engine (part # 10067353). All GMPP engines only have a limited (parts only) 12 month warranty.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-16-2007, 07:38 PM   #8
xtreme80
xtreme80's Avatar
It's the 290 horse engine. The warranty card that I got with it says they will warranty this engine if it was installed by a GM tech.
Old 04-16-2007, 10:52 PM   #9
boatpuller
boatpuller's Avatar
that was probably in the"ol fine print" by the time you pay the chevy garage to install it...it probably about doubles...hope it works out for you.man.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 04-16-2007, 11:49 PM   #10
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Damn, that really suxs. I can't believe 2,000 miles and its burning oil. Thats bs about the warranty too. Hope it all works out good!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
