Old 04-15-2007, 10:21 AM   #1
cc_bob
a arm question. 3/4 and 1/2 tons
I pulled down my 72 c20 yesterday to go through the front end (new upper and lower control arm bushings, ball joints, etc..) and found one of the bushings on the lower a-arm were worn into the a-arm itself. I have a couple of 1/2 ton 67 parts trucks.
Is the lower a-arms the same?
67 C10 396 stepside project
72 C20 402
72 K10 SWB (plow truck)
86 K20
cc_bob is offline   Reply With Quote
Old 04-15-2007, 08:29 PM   #2
JimKshortstep4x4
Re: a arm question. 3/4 and 1/2 tons
The lower "A" arm shafts are the same but the lower ball joints are not. The lower ball joints mount up completely different as the C-10 ball joint presses in and the C-20 bolts in, (or is riveted). It looks like you will need to find an "A" arm for your C 20.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-15-2007, 09:59 PM   #3
crazy longhorn
Fabricate till you "puke"
Jim
Both press, but the 20 series has a larger hole in the arm... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-16-2007, 02:27 AM   #4
Aarons72s
Just go and find a 73-87 3/4 ton and get the lower a arm off of it. They are the same as 67-72 3/4 ton a arms. And I second the larger hole. I tried to put 3/4 ton ball joint in a 1/2 ton a arm. Big difference in the diameter Hope this helps.
Aarons72s is offline   Reply With Quote
Old 04-16-2007, 05:32 PM   #5
cc_bob
I thought 73-87 used a rubber bushing, maybe it's just C10s that use the rubber bushing. Or maybe I'm confused (wouldn't be the first time)
I'll checkout the local boneyard to see if I can find one. A 73-87 should be a lot easier to fine.
Thanks again for the help, I REALLY appreciate it.
Bob
72 C20 402
86 K20
Old 04-18-2007, 07:17 AM   #6
Aarons72s
C10 s made the change to rubber bushings in 73. The 73-87 3/4 tons used the same a-arms and disc brake spindles as the 67-72's.
glad I could help.
