gas tank
What do you guys recomend? Poly or steel? I am going to be replacing my tank.
Re: gas tank
This thread http://67-72chevytrucks.com/vboard/s...d.php?t=212828
has a few excellent pointers and warnings about steel 'replacement' tanks. |
Re: gas tank
This is what I did. Not much more $ when you factor in the hassel of swapping necks out on reproduction tank. Also won't get banged up when offroad & can smooth out qtr panel where cap came through.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
![]() Join Date: Feb 2000
Re: gas tank
I've read, but no personal experience, that the poly tanks can start sagging so that was enough for me to go with a new steel tank. I need to remember to post up the product info on the tank as it worked very well with just cutting off my old neck and using a short piece of fuel hose to connect it to the new tank.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#5 | |
Re: gas tank
Thanks |
