04-17-2007, 10:09 PM | #26 |
Active Member
ZZ454 in my '72
All that seems simple is not... Trucks running well attached are pick of the CPP trailing Arm Crossmember, DTS rear end cover, there is an Eaton 3.08 posi hiding behind it, and the exhaust crossover pipe. Hopefully tomorrow it will be on the road.
"The Great State of Florida" Last edited by KFreddy; 04-17-2007 at 10:14 PM. |
04-17-2007, 10:11 PM | #27 |
Active Member
Re: ZZ454 in my '72 - pics
A few more pics, sanderson exhaust manifolds, 2.5" primaries and 3" exhaust...
"The Great State of Florida" |
04-17-2007, 11:42 PM | #28 |
The Original HotRod KnifeMaker
Nice job!
If you come take me for a ride in it tomorrow [I promise not to ask to drive] I will buy us each a tall double latte? Call before you come, OK?
Dave 69 GMC SWB 2WD 454 Turbo 400 |
04-18-2007, 12:45 AM | #29 |
Active Member
Right, Miami to washington, in like 4 hours. I know a short cut???
04-18-2007, 01:25 AM | #30 |
GEARHEAD
I know you may not want to hear this question but, I have to ask.
HOW long is your slip yoke on your drive shaft? Is it in the back of the tranny far enough? It may just be the pic's but I had to ask to be sure. I would not want to let it be unsaid and have something bad happen. I hope every thing is cool since you are so close to being on the road. RJ22 |
04-18-2007, 01:38 AM | #31 |
maybe its just the suspenion sag since its on the lift making it look like its ready to come out
looks really good though, let us know how she runs and take some pictures and/or a vid of the burnouts you do
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-18-2007, 01:39 AM | #32 |
Are you using a mechanical or electric fan???
04-18-2007, 08:15 AM | #33 |
computer illiterate
what is that on the oil filter? what is it for
72 2wd blazer 72 swb 4x4 Last edited by meathead95; 04-18-2007 at 08:15 AM. |
04-18-2007, 08:43 AM | #34 |
Active Member
Using a 19" reverse spin, flex-a-lite mechanical fan.
It's a filtermag on the oil filter, pretty much a giant magnet that keeps any metal bits as small as .02 microns in the filter. Worked great on my '96 ImpalaSS So i figured why not use one again.
"The Great State of Florida" Last edited by KFreddy; 04-18-2007 at 11:55 AM. |
04-18-2007, 09:34 AM | #35 |
Is it, basically, a flex flan & I assume you are not using a spacer, right. How far is the fan away from the radiator??
04-18-2007, 11:58 AM | #36 |
Active Member
It's got about 1/2" of clearance from the shroud and just enough to clear the radiator, were talking inths here. I would like to use a smaller fan, less rotating mass, however it gets awfully hot in Miami, even in the "winter time" it can be in the high 80's.
04-18-2007, 11:58 AM | #37 |
computer illiterate
cool ive never seen that before
72 2wd blazer 72 swb 4x4 |
04-18-2007, 12:09 PM | #38 |
Once you go BBC you don't go back!!!!! Mine was a bit of a challenge, but only because I was using wrong parts and made them work. I'm doing another BBC in another 69 right now. This time it'll be much easier, since I have experience and the right parts this time.
Looks good.... A....
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
04-18-2007, 01:13 PM | #39 |
Thanks for the info...I am going to be using a 454 with an OE serpentine system...I wasn't sure about fan clearance....Have you ever thought about electric fans.....
04-18-2007, 01:19 PM | #40 |
oh man oh man. Congrats on one nice set up!
Alex 1971 Lil' Red 350 SBC 700R4 |
04-18-2007, 01:49 PM | #41 | ||
im using sanderson headers, too. what starter are you running?? mine was hell to stuff in there and im still having clearance issues Last edited by tavenner13; 04-18-2007 at 01:51 PM. |
04-18-2007, 01:55 PM | #42 |
Active Member
Make it a Black and tan and I'm there, you can't get a DUI in Texas, can you...
