Old 04-18-2007, 05:12 PM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Shock Relocation
Im sure a few of you have done this with a kit. My question, how did you get the old mounts off without taking the bed off? Used my 4.5 inch grinder and lowered my exhaust and I have one side off, but now how do I get the old rivets out?
VDOG is offline   Reply With Quote
Old 04-18-2007, 05:41 PM   #2
SCOTI
SCOTI's Avatar
Re: Shock Relocation
Grind them flush & drive them out w/a air chisel (easy way ) or a punch & hammer (not so easy).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-18-2007, 06:14 PM   #3
VDOG
Grand PooBaa Member
VDOG's Avatar
I was trying not to grind them out, getting lazy. Going on 3 weeks doing this install. Nver enough time in the day.
Old 04-18-2007, 07:07 PM   #4
53lowdown
Junior Member
53lowdown's Avatar
I used a center punch to ding the rivit head in the center, then a 3/8 drill bit to drill through the head. Then punch the rivit out with a punch and bfh
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 04-19-2007, 12:38 PM   #5
VDOG
Grand PooBaa Member
VDOG's Avatar
BFH?
Old 04-19-2007, 12:48 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Originally Posted by VDOG View Post
BFH?
Big effin hammer
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-19-2007, 01:21 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Get a flap wheel for your grinder at Home Depot and you'll be able to grind those flush in about 30 seconds each. Then, like mentioned, they will punch right out.
Also, fit a block of wood between the flange of that crossmember and the bottom of the bed, right next to the rivet while hitting the rivet. The crossmember is flimsy enough that it springs a bit when struck with the hammer and than takes away from the effectiveness of your force.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-19-2007, 01:30 PM   #8
68CHEBY
If you have an air hammer use a chisel bit and knock the head off of it then use the air hammer to knock the rest of it out, not the quietest way but for me it has been by far the simplist.
68CHEBY is offline   Reply With Quote
Old 04-19-2007, 01:52 PM   #9
VDOG
Grand PooBaa Member
VDOG's Avatar
That was the first thing I tried, my air hammer did not make a dent.
So I used the grinder. Just have to get back under it, and finish the job.
Old 04-22-2007, 03:48 PM   #10
VDOG
Grand PooBaa Member
VDOG's Avatar
Got the old shock mounts and installed the new ones. Unless I did something wrong, the new shock relocator parts are not as great as I thought. I'll post the pictures within the hour.
Old 04-24-2007, 08:14 PM   #11
VDOG
Grand PooBaa Member
VDOG's Avatar
Are the shocks bushings supposed to be slanted at the bottom?
Also the kit has a mounting bolt that hits the shock as you can see in the picture. You have to install the upper screw with the nut half way then install the shock then tighten the screw the rest of the way. PIA!!
Old 04-24-2007, 11:02 PM   #12
SCOTI
SCOTI's Avatar
Wow! That bottom shock does look waaaaaay out of align.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-25-2007, 07:50 AM   #13
Tx Firefighter
Flip that upper bolt over to where the head is on bottom and the nut is above the crossmember. That will fix that problem at least.
Old 04-25-2007, 08:32 AM   #14
Hart_Rod
Hart_Rod's Avatar
Do you have an adjustable panhard bar? Looks like your rearend is misaligned.
R
Hart_Rod is offline   Reply With Quote
Old 04-25-2007, 08:38 AM   #15
arkracing
Weekend Warrior
R
Yeh what he said
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 04-25-2007, 11:27 AM   #16
Shock_Me
Shock_Me's Avatar
My lower shock mount kit from ECE has a spacer between the shock and the mount. Don't know if that would solve the mis-alignment problem though. I'll take a pic tonight when I get home and post it for you.
Pete
Shock_Me is offline   Reply With Quote
Old 04-25-2007, 12:12 PM   #17
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
What does the other side look like? Can you post pics of the opposite side? If we could see how that shock sits on the mounting stud, that would tell us alot.....
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-25-2007, 12:37 PM   #18
PunkRock247
PunkRock247's Avatar
Here are some pics of mine. I hope they help. They are the best pics I could get with the truck still on the ground. Not easy for a guy my size getting under a lowered truck
1969 Chevrolet C-10 SWB
PunkRock247 is offline   Reply With Quote
Old 04-25-2007, 01:13 PM   #19
VDOG
Grand PooBaa Member
VDOG's Avatar
Looking at PunkRocks pictures, I think my shock mounts were made wrong. His mounting bolt is nowhere near the shock where as mine hits the top of the shock.
Old 04-25-2007, 01:15 PM   #20
glock35ipsc
There are definately some difference here, but nothing is jumping out at me right now except for the rear end not being centeres. VDOG, some pics of the left side would tell us a bunch.
Also VDOG, who made your kit? And how much is your truck lowered in the rear?
Bob
Old 04-25-2007, 01:40 PM   #21
PunkRock247
FYI...I got mine from Early Classic Enterprises
Old 04-25-2007, 02:36 PM   #22
VDOG
Grand PooBaa Member
VDOG's Avatar
I will get you a picture of the passenger side in a few minutes. I got mine from Classic Performance Parts or CPP.
Look at the screw that in the old shock mount hole. Do you see it next to the shock? Its pressing against the shock.
Old 04-25-2007, 02:54 PM   #23
70c10
67-72 Addict!
70c10's Avatar
vdog- the part that your bottom mount attaches to looks bent to the left. Look at the angle compared to punkrocks!.
Jim
Old 04-25-2007, 05:50 PM   #24
VDOG
Grand PooBaa Member
VDOG's Avatar
The truck has a 3" drop in fron and a 4" in the rear.
Maybe I should install the panhard bar, maybe that will align the shocks.
So where do I mount the adjustable part of the panhard bar? On the axle or on the driverside mount?
Pictures are the driverside of the truck as requsted.
Old 04-25-2007, 06:05 PM   #25
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i'm not sure why your having the issues you are, but i would definitely run a panhard bar. at least the factory one, if not an adjustable one.
all of the adjustable panhard bar setups i've seen has the adjuster on the D side mount.
IvelDesigns is offline   Reply With Quote
