Old 04-15-2007, 05:48 PM   #26
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: updated pics, need your opinions too
I agree awesome looking truck and I also got to say lowering the front a little bit more will get u where u want it at!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-15-2007, 08:58 PM   #27
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Originally Posted by bigblock73 View Post
Marcus, thanks for the photoshop...I believe the 2" additional drop looks the best!
by far!
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-16-2007, 10:54 AM   #28
Ric83
Ric83's Avatar
BTW, truck is looking great! Getting excited to see it finished myself.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 04-16-2007, 01:52 PM   #29
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have the same issue. Mine is actually a hair lower in the front than in the back. The wheelwells, though, make it look look the back is lower than the front. I'm trying to decide whether to go 1" lower in the front or 1" higher in the back.
I know it would look better lower in the front, but it is a daily driver. I think higher in the back would make it ride better. It would also make it haul stuff better,and that is an issue since it is a daily driver.
Slonaker
EDIT-I forgot to say that you should lower yours another inch or two. You don't daily drive it, so do what looks best.
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-17-2007, 12:14 AM   #30
bigblock79
67 Chevy Stepside
bigblock79's Avatar
2" coils will do the trick
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 04-17-2007, 06:19 PM   #31
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
It won't settle 2", but you can cut a coil out of it after it does settle.
Definitely drop the front. BTW, it looks sweet!
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-17-2007, 06:31 PM   #32
benoit454
Chris
benoit454's Avatar
Let me ask you axle flip kit/c- notch guys a question,
Doesn't it make you feel or think unsafe cutting the frame? That part always scares me, I'd be afraid it snap going down the road or in a wreck or hauling something. I wonder if it's the weak point since the frame gets cut.
Also another question, can one flip kit.c notch and then add shackles and front hangers to make it even lower????
Thanks in advance guys, I mean don't get me wrong I'd love to flip kit and c-notch but it just scares me to compromise a frame like that, however other then hangers/shackles there's not much room left for a drop in the rear. Except for like de arches or less leafs.
You guys with dropped trucks ever haul anything? Load of trash, rocks? dirt? atv anything like that in the bed? if so does it bottom out and put it in danger? or still ride ok loaded?
I'm seriously considering dropping the 84, but we gotta haul stuff in it and use it as a truck, haul my atv, garbage, scrap, dirt, rocks, you name it.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-17-2007, 07:11 PM   #33
bigblock73
yeller
bigblock73's Avatar
Chris, while I am no expert on c-notching frames, I doubt there would be a problem if done correctly. Here is a pic of Swervins notch, as you can see, it looks lenty sturdy. I have the same kit in Yeller, and these things are real nice, real heavy (thick GA metal), and the welds are absolutely perfect. Also, you have to remember, once the bed is bolted down tight, that adds another area of added strength.
bigblock73 is offline   Reply With Quote
Old 04-17-2007, 07:14 PM   #34
bigblock73
yeller
bigblock73's Avatar
Update fellas, I ordered some 3" drop coils, it will leave Yeller with a 6/8 drop when it is all said and done.
Thanks again, and glad you enjoy the updates, I will kep them coming...hopefully at a faster pace as I am getting closer.
Old 04-19-2007, 01:06 AM   #35
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I'd like to think that reputable 'aftermarketeers' do their homework when they produce these kits. Like you, I would guess by the very nature, that it does weaken that point of the frame rail and lessen the load capacity of the truck. But, like Jeff says, if properly done, it shouldn't be a problem. I've seen pics of c-notched trucks that were rear-ended and other portions of the rail were damaged except the c-notch. One trick is to reinforce behind the c-notch with bar stock.
Probably, but you want to try to maintain at least 3" of suspension travel between the axle and the frame rails (c-notch). This also includes the travel between the pumpkin and the underside of the bed floor.
If you're gonna be haulin', you probably need some helper bags or maybe a hollow bump stop like these that I posted in an earlier thread:
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-19-2007, 01:07 AM   #36
boxrodz
boxrodz's Avatar
boxRODz
