04-16-2007, 05:35 PM | #1 |
Junior Member
Whats a '70 cab worth? should I buy it?
Came across a 70 CST cab today. It has some holes in the ds rocker, and needs rear and probably front cab supports. Top and rain gutter are solid. All glass is there, bench seat, solid floors, and pretty nice doors. No dash, pedals etc. The back of the cab looks like the bed hit it at one time, but its not too bad, and may be able to be pushed back out. Above the heater core area on the firewall there is a crack/rusty area thats not real bad either. I think my K5 is rusting there too. Id like to put this cab on my 72K5 frame. Can I put my high hump tunnel on this cab for my shifters and basically drop it on. Will the cab mounts line up with the K5? This cab can be mine for about $350. Since these are getting harder to find, should I jump on it, or should I hold out for a better one. Didnt take any pics, but I think I described it pretty well. Opinions welcome!
thanks.
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker 89 XJ Pioneer, 4.5" 32s. 98 ZJ DD. Parting..87-01 Cherokees I bore throttle bodies-PM me for details! |
04-16-2007, 05:40 PM | #2 |
Recovering 67-72 Addict
Re: Whats a '70 cab worth? should I buy it?
Too bad that you are on the other side of the country. I have one that I would give you. It is going to the recycler this week!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
04-16-2007, 05:42 PM | #3 |
So,you want to go from a blazer to a blazer frame and truck cab?The rear mounts for the cab from a truck will need to be switched over to the blazer chassis.The tranny hump hole is the same,the 2wd auto trucks had a welded in low hump though.The 4x4s and floor shifts had the high hump that bolts in.So,what do you plan to do bed wise?
04-16-2007, 06:42 PM | #4 |
Junior Member
Im probably just going to build a flatbed out of tubing and diamond plate with built in tire carrier and high lift jack mounts etc. Not sure what you mean about the cab mounts though. Could you expand on that a bit?
04-16-2007, 09:03 PM | #5 |
Does it have to be CST? I'm not sure how rare they are. If you are just looking for a good 67-72 cab , you can do a lot better.
04-16-2007, 09:28 PM | #6 |
i dont see why it matters if its a cst cab, its obdviously not on the truck and will need bodywork and such, and im sure it doesnt com with a title, so what diffreence would it make? the only thing i'd be concerned about is the actual condition of it, and if it has a/c or not.
04-16-2007, 09:29 PM | #7 |
and btw... ive bought half decent cabs for 50$ and got a FREE one just today... so $350 is steep
04-16-2007, 09:49 PM | #8 |
The cab we have talked about is in better shape than that but not as complete. It does have rocker and cab corner rust, and a little in the fire wall but cab supports are solid. I pm you will have pix soon.
Thanks, Steve |
04-16-2007, 09:59 PM | #9 |
Junior Member
Sounds good Steve, looking forward to seeing them. I dont care what year cab I get, but if its a 70-72, all my dash parts, column and pedals should all transfer right in. I also dont care about A/C for now. Can always get aftermarket for about $1200. I just really wanted one that doesnt need too much bodywork, as Im going to have to pay someone to handle that part for me.
04-16-2007, 10:10 PM | #10 |
Recovering Truck Driver
$350 is a little rich, I bought my cab for $100 and it has very little rust. It's not a CST and it doesn't have air. If you could figure a way to pick it up, I'd give you the cab I pulled off...but it's pretty rusty.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
04-16-2007, 10:16 PM | #11 |
Not to hi jack, but....Breeh, What is the condition and specs on your cab. My cab needs replacing and Im up in Monroe. PM me if you still have it. Thanks, Eric
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
04-16-2007, 11:01 PM | #12 |
That rear cab damage can be near impossible to fix.Then,there`s all the other rust areas you mentioned.The guy`s got nothing and he wants $350.What does that make a rustfree cab worth?
04-18-2007, 09:25 PM | #13 |
Junior Member
Thanks for the pics Steve....and to all that offered up cabs for free, etc. The one Im looking at is actually pretty nice, all things considered. A nice rust free cab with doors and glass....Id say at least $800. Id gladly pay that for a really nice one. Im going to offer $300 and see if the guy bites. If he does, and put some pics.
04-19-2007, 01:26 AM | #14 |
Eric, it needed rockers but sorry, I hauled it off to the recycler today.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" Last edited by breeh; 04-19-2007 at 11:32 AM. |
04-19-2007, 07:05 AM | #15 |
I gave away a rustfree cab that had back panel damage.After showing it to several bodymen,I decided it wasn`t worth fixing.The estimates were from $800-1,500.I gave it to the guy for parting out the truck.By the time you figure all the other work,that cab`s going to cost you more than $800.I`m not saying the cab`s not salvageable,but it ain`t worth $300 IMHO.
