Dave's not here, man
Re: Help w/ rear main seal replacement
Is it a one piece?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
I don't know.
72 C10 lwb fleetside -stock 350/350 combo |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Yeah- that would require a totally different approach if you have an '87- up block.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
Well, Whoop-dee-do!
The "heavier" lip goes inwards. The offset seal is only needed if a groove/ rough wear is found on the crank.
Quickest way to tell if you have an old 2- pc. seal block is to look at where the flywheel bolts on. If you can see the bolts protruding thru "open" holes, its a 2 piecer'.
Ahhhhh! I was wondering what the difference between the 2 is.
The block is a '74 so I'm good. So now I hope I can follow your directions w/o screwing it up. Thanks!
