61 rear end question
my 61 has a rear end with a 3rd member and the diff cover is almost perfectly round with 10 bolts. it has6 lug axles. what is the name for this rear end?? and does anyone how if there is a 5 lug axle that will swap into it?
100% gearhead
Re: 61 rear end question
It is the old school Eaton 12 bolt. It is impossible to find parts for these. Nothing is made aftermarket except very little, and there are no 5 lug axles available unless you have someone like Currie or Moser make some. I Professionally rebuild rearends and own a '62, so I have learned a thing or two about this rear. Swap to a later '63-'68 (narrower), or '69-'72 (wider), and a whole world of goodies opens up to you.
thanks, i have a 12 bolt from a 82 c-10 that is 5 lug, how much wider is it than the stock axle?
#4 | |
Not a bad nut after all..
'73-ups are only available for leafs, staggered shocks, bumpstops on the frame, and have wider spring perches. I'm not a '60-'66 expert, but I've done a number of leaf spring rearend swaps on '67-'72 and '73-up trucks. Is your '61 leafs or coils?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
my 61 is coil, but im well versed with a torch and welder to slice off the old pads and add the new ones and panhard bar mount. i can deal with the 3/4" per side with backspacing when i get ready to buy wheels. thanks!
