Old 04-20-2007, 11:56 PM   #1
northerngmc
northerngmc's Avatar
Fuse for radio
I am installing a factory AM radio in my 69 GMC out of my 70 GMC parts truck.
What type of fuse goes in the fuse box for the radio?
I am thinking that my power lead from the radio plugs right onto the front of the fuse box.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 04-21-2007, 12:37 AM   #2
jhow66
jhow66's Avatar
Re: Fuse for radio
Radio feeds off the heat fuse (to check just flip fuse up on one side to see if radio goes off.)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-21-2007, 01:24 AM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Fuse for radio
i have an after market deck in mine and i just found a good power source and pluged into it, i think it might be that plug to
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-21-2007, 12:03 PM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Fuse for radio
The fuse labels in that photo are a little off, if you have a non-ac truck. The radio fuse is the one labeled "heat", and should be 3 amps. If you have AC, things are a little different, look in the factory service manual for your year, it tells you exactly what is different with a factory set up.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-21-2007, 12:54 PM   #5
northerngmc
Re: Fuse for radio
Well that helps, my heater motor wasn't working and the fuse was good. But when I changed the AC fuse the heater motor was getting power again.
Blaine
