Old 04-22-2007, 10:15 PM   #1
corkscrew
Which one is the ground wire??
For my flaming river steering column?
corkscrew is offline   Reply With Quote
Old 04-22-2007, 10:31 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Which one is the ground wire??
Can you check it with an ohm meter?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-22-2007, 10:40 PM   #3
corkscrew
if i had one lol so no i cant...if i got one where would i check?
Old 04-23-2007, 02:55 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it shouldn't need a ground wire. IIRC, they use a normal GM turn signal switch, wich I am pretty sure doesn't use a ground wire.
