Garage Queen Material
rust sucks
so, while the truck was sitting so long, and the master cylinder was leaking, it was dripping right on the inner fender
all the paint on the fender is all crackly and peeling now and its being a bee eye tee see ahe to get cleaned up. i decided the other day i'm taking the truck down for some well needed tlc in the engine bay and front end. i'll be moving some things around and cleaning up along with replacing the carburator. but step 1 is cleaning, which means getting as much of that old rusty paint off the inner fender and repainting it. oh, and whats the best way to clean my intake manfold without removing it? its gotten a little dirty in some spots and i want to make it look so fresh and so clean clean again |
Re: rust sucks
you have been posting alot lately... have you been home more or just get on at work?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Re: rust sucks
Re: rust sucks
Did you say rust or a bad inner fender? I'd just replace it, Mine was rusty below the battery box on the passenger side. found a set on craigs list for like 60 bucks. Took like 10 easy to get to bolts and about a half hour. fact is I still have the driver side one I need to get rid of. to bad your a long way from ore. good luck.
Re: rust sucks
yeah, i was thinking about just replacing them, but i dont know if i wanna replace them.
its not rusted very bad, just surface rust really |
Chris
Re: rust sucks
I would just sand it down, prime it with self etch primer or epoxy to further stop the rust, from either starting or coming back through, then paint it. if sanding doesn't work try a grinder or wire wheel. Maybe even por-15 or something.
As for the intake if it's alum. I used some brake clean and a brillo pad on mine, it was just reg. alum. not polished or any fancy coating and once done it turned out very nicely, like brand new. it had dark spots and stains from a leaking thermostat housing when I cleaned it, also had it off to do so and get all the little areas. Even had overspray on it, now it's all clean like brand new.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
| Bookmarks |
