Old 04-24-2007, 09:41 AM   #1
AlienYouth
AlienYouth's Avatar
brake question
well the other day i busted my front brake line, so i have to replace it all. there is a half inch line runnin to a junction box, and then two 3/8 lines running from the junction to the rubber hose that goes to the drums. I bought lines but cant seem to find a 1/2x3/8x3/8 junction box, anybody seen these online or had the same issue? ima go run around to some other stores today and see what i can see, but if i cant find anything, you guys know of any good brake part sites?
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 04-24-2007, 08:44 PM   #2
dirtball
dirtball's Avatar
Re: brake question
The dimensions you are talking about sound like the wrench size for the fittings. The actual line size is what you should be using. Likely it is 3/16" and 1/4" lines. I think this is why you are having problems finding your part.
dirtball is offline   Reply With Quote
Old 04-26-2007, 02:52 AM   #3
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: brake question
Yep, it's a single 1/4" in, dual 3/16" out block that you need, can be had at any parts store for just a couple of bucks.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
