Right turn Clyde
Re: What manifolds will work on 86 305?
The 350 manifolds will bolt up. But the collector/doughnut gasket area maybe of different diameter. So that means you will need to find the correct size Y pipe or have one made. If you have any type of emissions check you will want to get the correct type manifolds with the air tubes.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
| Bookmarks |
