Oilfield Trash
Longer Throttle Cables?
I'm doing a cruise control swap on the 72 and ran into a snag, my throttle cable to the gas pedal isn't long enough! It worked fine before, but now it has to go around the cruise actuator and it won't reach. Check out pic#2 in this faq write up http://67-72chevytrucks.com/vboard/s...d.php?t=151318 so you guys can see what i mean. Does anyone make a longer cable? would swapping to a big block or 4wd cable be any longer?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
member #16
![]() Join Date: Dec 1999
Re: Longer Throttle Cables?
See if you can get someone to measure a 6 cyl. cable. Im thinking I heard they are longer.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Oilfield Trash
yeah that might work, as long as it mounts to the carb the same way.
you can always go with an aftermarket cable like one from Lokar.
They come in 24" or 36", pretty much trim to fit. ![]() ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 04-29-2007 at 11:38 PM. |
#5 | |
Licensed to Thrill!
DLB |
