pitman arm
how do you take off the pitman arm does it just pop straight off with alittle persuasion or do you need a special tool?
![]() Join Date: Mar 2003
Re: pitman arm
You will need a puller, the splines are tapered, so when the nut is torqued down it locks it very tight.
Big Block
Re: pitman arm
You can pick a pitman arm puller up at any auto parts store. They are not to expensive.
Licensed to Thrill!
Re: pitman arm
I used a puller alright...looked like this...
![]() I would recommend it their way though. It's not the easiest way. DLB |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: pitman arm
You need this
Re: pitman arm
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
