05-01-2007, 04:37 AM | #1 | |
glamoros piece o' lowlife
Re: Help!!!......Frustrated......
Oh, and just as an idea - my 350 has a Melling high-volume (not high pressure) pump, runs on Rotella-T diesel oil (by recommendation from Melling), and normally pegs the gauge, the lowest I've seen the pressure is about 45-50psi while idling in gear at a looong red traffic light. Pump is supposed to crank out about 70psi so it all makes sense. On a fresh bottom end you should be seeing similar numbers, maybe a little lower but still over 30psi at warm idle in gear at a red light.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express Last edited by Ivan D.; 05-01-2007 at 04:44 AM. |
