4 Speed Questions
I have a granny low 4-speed in my truck. Will the factory crossmember and everything for the clutch work with a truck 3 speed?
It gets stuck in 3rd gear when i come to a stop. Its kinda hard to get it in 3rd gear. And i cant downshift at all.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
Re: 4 Speed Questions
If you have the heavy duty Muncie SM465 they have the 5 1/4" front bearing retainer, all the rest are 4 1/8" so you will need a different bell housing.
Here's a link I got for transmissions they sell rebuild kits with complete instructions. I got a SM465 I'm going to rebuild befor I put it in my 68 C20. http://www.novak-adapt.com/knowledge...on_gateway.htm Last edited by airdale94; 05-01-2007 at 05:23 PM. |
ok what about the clutch linkage...i think its called a Z-bar? And what about the driveshaft will it slide in to a truck 3-speed?
Is your clutch releasing properly? What you describe does not really sound like a tranny issue.
Tim |
#5 | |
Yes im sure its releasing properly. once i get it in gear it will go and not slip. It just seems that this tranny is not syncronized.
#6 | |
Thanks, but ive wanted to put a 3-speed in it. Or a car 4-speed. Im wanting to build another truck just like i had in high school.
Don't know for but I would think the Zbar and linkage would all be fine. Have no idea on the drive shaft.
![]() Join Date: Jul 2005
I have a car 4 speed in one of my ole rides. Drive shaft is a one peice and worked out just fine. Fact is took out the old tranie installed the 4 speed . No issues of any sort. Wait I did run out of pepsi
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
