Old 12-02-2002, 11:08 AM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Looking for Hydraulic Ram. ...see pic
Does anyone know where I can get one of these rebuilt or new. Power steering fluid is leaking out of the shaft area. The O rings are bad and the shaft may be worn so replacing the o rings may be useless.
Thanks,
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 12-02-2002, 11:31 AM   #2
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
the only thing i know of is called a rock ram. might be too powerful for a stock application tho. it's supposed to be for 44 inch tires. check out a 4x4 shop and they should be able to get one. i couldn't find a link. not much help but ...
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 12-02-2002, 11:59 AM   #3
JimKshortstep4x4
Talking
I believe that the Corvette cylinders are the same, (they look the same), but it would need to be verified. Anyway, if they are the same, Paragon has rebuilt cylinders for $75 exchange, ($95 with no exchange) or they have new imports for $120.
Rebuild kits may be available, but I don't know who has them.
Corvettes has the same cylinder from 1963 to 1982.
Here is their link in case you want to check it out:
www.corvette-paragon.com/
Jim
Old 12-02-2002, 02:02 PM   #4
Zumo
Hot Rods For Life
Zumo's Avatar
I e-mailed them.
Does anyone have a 67/68 truck in the Texas area they are parting out that may have one of these not leaking?
Andy
Old 12-02-2002, 03:05 PM   #5
68 Suburban
68 Suburban's Avatar
I have the complete set up in Phoenix. The unit I have was "sweating" when I removed it. By that I mean it was wet on the outside, but it never seemed to leave fluid on the ground, or ever need fluid added.
To find one of these that are dry is virtually impossible. I think even after having it rebuilt, you will see some 'sweating' very shortly. It is the nature of the beast.
I think there is a place in the south suburbs of Chicago that rebuilds these. I can't remember the name of the place though.
68 Suburban is offline   Reply With Quote
