steering column ?
Hello, I need some info on a steering column problem, this is on a '72 3/4 GMC. It seems that I can pull on the steering wheel and it will pull out about a half inch or so. I was told my column was worn out. I priced a rebuilt tilt steering column, they sell at the local swap meet for about $250. Not sure if this is a good price or do I just need a new steering coupler? Any info? Thanks
'72 GMC custom camper 350/350 |
Ya know, not to be a smart ass, but mine does that too, I just don't pull on it.
its all about the +6 inches
My first two did that...but I can't remember on the one ton...the steering wheel has been off for so long I just can't remember.
I know if the upper bearings are shot, it'll cause some slop, but I doubt that's the problem the way you describe it. |
I bet a new rag joint would help.
I doubt it...the shaft shouldn't pull through the column regardless of the rag joint.
Does it have up and down slop in it too? |
GMC SHORT FLEET F/S
Humm?
CHARLES WADE HEIN HVACR FOREMAN. LEWISBURG U.S.P. |
No up 'n down slop. And not much slop in the steering either.
I dunno, I would have someone pull on it while you were under the hood. See where the pull comes from. I would think a rag joint, would help some of that.
LMC has all the stuff to rebuild it and it's not that hard to do. I did the one in mine. You should be able to pull it, rebuild it and get it back in a day.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
There should be a spring at the lower end of the steering column
which holds the upper and lower bearing in a preload. If you pull up on the wheel, you can overcome the spring and the wheel will move approximately 1/4". You may want to check the spring and make sure it is in place. Also, there should be a large thick washer between the spring and the coupling. Jim |
SKINNY TIRES RULE!
Mine does the same thing. Since I have some lame aftermarket steering wheel, I can see the upper bearing. When I pull on the wheel (actually, all I have to do is just touch it) the upper bearing will come out of it's possition. I have looked under the hood and the problem is not in the rag joint. I believe that mine is missing the spring JimKshortstep4x4 mentioned and possibly some retaining clip or spring on the upper bearing. I have considered rebuilding it but I just haven't gotten around to it yet. I have noticed they have the parts in LMC but I'm not sure what all I need yet.
Let us know what parts fix yours if you decide to rebuild.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Grand PooBaa Member
I had that same problem. I went to the junkyard, found a Chevy van, about a 76 or 77. Pulled out the tilt column, and called it a day. 45 bucks allday long. Problem is, some people will tear then up trying to take them out. If you find one not too badly damaged, buy it and get it repaired. I like the Lokar, but dont have the 550.00 to pay for one.
