05-08-2002, 05:54 PM | #1 |
New U-joint for you 4x4 guys
Just looked at CTM U-joints, bearing less, blow proof. Not cheap, $150 a pop. They have em for the front axle Dana 60/44/30 right now but there working on rear shafts and 2wd also.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
05-08-2002, 07:04 PM | #2 |
Registered truck nut
Pretty cool but another though is that I want my U-joint to be the weakest link. There relatively cheap and easy to replace. Those look like, I'd twist the driveline or axle shaft before they broke. lol
------------------ MOUNT VERNON, WASH. STATE GOT MY BASES COVERED -Big and bad 70 CST Blazer -71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo, -Work in progress 72 SWB -72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd. -71, 3/4 ton, 402/400, Custom Camper -69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER" -69 Chev. short narrow 4x4 -69 Chev., lwb, utility trailer, 35" tires, Add or Delete Daily
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
05-08-2002, 10:14 PM | #3 |
Glowing since 1978
I second the weakest link idea. The vette has a 454 and six u-joints two on the driveshaft and four on the half shafts. I'd rather replace them than rebuild the rearend.
------------------ 66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 79 Chevy 4X4 (Tom's old truck)
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
05-09-2002, 12:36 AM | #4 |
Collector of rusty Items
Spinning rubber is my idea of a weak point. Do they make that joint in a 1410?
Got a link to these joints? Thanks ------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
