Old 05-04-2007, 05:53 PM   #1
krue
Designated A-hole!
krue's Avatar
2/4 drop?
What's a cheap way to do this? Thinking of doing it on my truck. I've got a spare set of springs on a parts truck if cutting/heating is what I go with and I don't like it. What's the best source for lowering springs? Just bouncing ideas around in my empty head.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-04-2007, 06:38 PM   #2
ChevyDude
Re: 2/4 drop?
Ece
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 05-04-2007, 07:02 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Re: 2/4 drop?
Krue- the cheapest way is to cut a coil out of your spare springs (FREE) and buy a set of rear drop springs at GMCPauls for $95(Cheap) You will not need to buy lowering shocks with this mild of a drop. Captain Keneival has my old cut springs on his truck now and they look great!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-04-2007, 07:29 PM   #4
Captain Knievel
Captain Knievel's Avatar
Re: 2/4 drop?
Yep. 3's in the front, Brothers $99 4-inchers in the rear. Before and after below
1970 C10
Captain Knievel is offline   Reply With Quote
Old 05-04-2007, 07:35 PM   #5
Redaddiction
LS1 Lover
Re: 2/4 drop?
How low of a drop can you accomplish up front with cutting springs? I have all the parts for my 6'' drop in the rear but the front requires alot more.
USMC
Redaddiction is offline   Reply With Quote
Old 05-04-2007, 07:49 PM   #6
Big D
Big D's Avatar
Re: 2/4 drop?
I'm also trying to keep my project low buck, I'm going to cut one coil off the front which should give around 2" drop. On the rear I'm going to try a 3" square tube drop like the one pictured here that Iveldesigns posted a while back.
I was going to start this weekend on this, but the GMC decided to blow a head gasket this week, so my priorities have changed. I'll post pics when I get it done.
68 GMC
64 1/2 Mustang convert
A bachelor's life is no life for a single man."
- Samuel Goldwyn
Big D is offline   Reply With Quote
Old 05-04-2007, 08:12 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Re: 2/4 drop?
On Captain Knievals truck springs, I cut 1.25 coils out of each spring and got a hair less than 3" drop as you see in his pics. I wouldn't cut anymore than that.
Jim
Old 05-04-2007, 08:27 PM   #8
Re: 2/4 drop?
Cut Springs?? How you going to get in and out of your driveway??
Old 05-04-2007, 08:42 PM   #9
Redaddiction
LS1 Lover
Re: 2/4 drop?
Thanks I am going to give it a shot tomorrow.
USMC
Old 05-05-2007, 07:14 AM   #10
57T210
Chevy Guy
57T210's Avatar
Re: 2/4 drop?
Jim,
In another post discussing cutting front coils, there was mention of the front coils 'popping' when turning. What should be done to avoid that?
Thanks.
57T210 is offline   Reply With Quote
Old 05-05-2007, 02:05 PM   #11
krue
Designated A-hole!
krue's Avatar
Re: 2/4 drop?
I thought you were only supposed to cut the springs an even amount of coils due to the way they fit in the cups.?
www.daveramsey.com
Old 05-05-2007, 02:49 PM   #12
jsbgump
Gone Fishing
jsbgump's Avatar
Re: 2/4 drop?
You can cut 1 ring out of the front coil and find some old big car springs to lower the rear. They won't take much of a load weight wise but they ride good and lower it to about what your looking for. I might even still have some
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-05-2007, 03:53 PM   #13
corn
Re: 2/4 drop?
Krue, heres the cheapest way. Cut one coil from the front springs & find a buddy that has an old set of chevelle, elcamino, cutlass style rear springs for the back. Free...
corn is offline   Reply With Quote
Old 05-05-2007, 04:10 PM   #14
krue
Designated A-hole!
krue's Avatar
Re: 2/4 drop?
I still plan on using my truck like a truck, so I've got to be able to carry a load. May just leave it stock height.
www.daveramsey.com
Old 05-05-2007, 05:26 PM   #15
jsbgump
Gone Fishing
jsbgump's Avatar
Re: 2/4 drop?
Well I still used mine as a truck some and it could get a little scary with a load in ruff road conditions. If your still gonna use it as a truck, my opinion is to either lower it the right way with the coponents from ECE or leave it stock. Just my .02
Build Thread
Old 05-05-2007, 05:49 PM   #16
huero
1969 Short, Fleet, and Beat
huero's Avatar
Re: 2/4 drop?
If, you plan on using you truck to tow and haul. Then, cheap should not be put into the equation. I am on the same boat and I plan on going 2" spindles in the front and a good set of 4" dropped coils from the rear. I am really thinking of Early Classics Enterprises for my parts.
huero is offline   Reply With Quote
Old 05-05-2007, 05:57 PM   #17
krue
Designated A-hole!
krue's Avatar
Re: 2/4 drop?
Forget it then, what's the point in having a truck I can't use as a truck.
www.daveramsey.com
Old 05-05-2007, 06:00 PM   #18
1969k10stepside
Re: 2/4 drop?
use the 3/4 ton as a truck and lower the gmc
1969k10stepside is offline   Reply With Quote
Old 05-05-2007, 06:02 PM   #19
krue
Designated A-hole!
krue's Avatar
Re: 2/4 drop?
Still don't have a title for the 3/4t.
www.daveramsey.com
Old 05-05-2007, 06:36 PM   #20
Wreckless_71
Wreckless_71's Avatar
Re: 2/4 drop?
Do it right... I accomplished my stance with 2.5" drop spindles and 4" drop coils in the rear. I'm really happy with the ride and stance, also you don't have to worry about any rubbing! My truck handles great and I regularly haul motorcycles, engines, snomobiles...etc. It does get a little squirly goin down the freeway with a bunch of weight in the rear... but that's only above 85 or so here's some pics of the stance.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 05-05-2007, 10:22 PM   #21
krue
Designated A-hole!
krue's Avatar
Re: 2/4 drop?
I'll put it on the list of "When I have some money".
www.daveramsey.com
Old 05-05-2007, 10:34 PM   #22
nvrforgotten52
nvrforgotten52's Avatar
Re: 2/4 drop?
with four inch coils in the back you would still be able to haul plenty... maybe not like a huge load...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-05-2007, 11:32 PM   #23
Boog
laying low
Boog's Avatar
Re: 2/4 drop?
Krue I know you said "cheap" but what about cutting a front coil, using passenger car rears and add a helper bag or air shock for a little assistance when hauling? Shouldn't cost all that much.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-06-2007, 12:59 AM   #24
wibilly
wibilly's Avatar
Re: 2/4 drop?
krue you can do what i did. i put taller tires on to fill my wheel wells. gives the illusion of being lower increases load capasity, and gives you a higher final drive ratio you win all the way around
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-06-2007, 07:20 AM   #25
57T210
Chevy Guy
57T210's Avatar
Re: 2/4 drop?
Wreckless,
That's a good looking truck.
Just checked out the ECE 2/4 lowering kit. Seems reasonable. Anything else one should figure on doing while they're installing the kit? For example, with a 2/4 drop, you wouldn't need the C notch, would you?
Regards.
