04-24-2007, 07:21 PM | #1 |
the green machine
who wants to help?
i need a wiring diagram made up. i'm completely confident in my ability to actually wire stuff up... as long as i know i'm doing it right.
i've got a MTX TA7804 amp -4 channel -class a/b -Remote Subwoofer Level Control Parallelable -100w x 4 at 4 ohm -200w x 4 at 2 ohm -400w x 2 at 4 bridged -800w x 1 at 2 bridged MTX 81001 amp -class D 1 channel -500w at 4 ohm -1000w at 2 ohm -1500w at 1 ohm -Remote Subwoofer Level Control Parallelable audiobahn flame excursion 10" woofer -450 rms -2" single coil 4 ohm 2x pioneer 6x9's, don't have any specs off the top of my head, or a model # i'm currently looking for a deck with all the hookups to make this easy. what should i look for in a deck (will probably buy used)? do i need a cap? i'm not looking for thumping bass, just a little bit of filler. do i need the D block or can i run the sub and 2 6x9's through the same amp? who wants to tell me how to wire it so i can draw up a diagram, or who wants to help? thanks mitch
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more... 2003 Suzuki TL1000R 1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more... My pictures |
05-01-2007, 05:22 AM | #2 |
>130dB Moderator
Re: who wants to help?
Is that everything...?
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
05-01-2007, 02:23 PM | #3 |
the green machine
i think i'm going to run the sub and 6x9's through the 4 channel and sell the mono block and buy a nice deck since mine's all ****ed up
05-01-2007, 06:36 PM | #4 |
>130dB Moderator
Only reason I asked it because you aren't going to get **** for sound out of those speakers...
05-01-2007, 08:22 PM | #5 |
the green machine
**** for sound as in...??? volume? clarity?
05-02-2007, 01:08 PM | #6 |
me thinks that ACEX is just messin' with you. I think the 4 channel Amp will be enough power to get you sound. get a deck that has atleast 2 sets of preouts. Good luck with you audio project.
05-02-2007, 02:47 PM | #7 |
the green machine
hopefully it's enough power, i think it should be. the 6x9's hit plenty hard for me in such a small cab. i'm not looking to roll around and bump, just get some decent quality sound with some bass to fill. i HATE it when people drive around and blast rap or some stupid **** with their sub rattling their car apart
05-03-2007, 11:55 PM | #8 |
>130dB Moderator
Those 6x9 speakers aren't gooing to soudn worth a crap...
A 6x9 just produces too much low-end for what you want and have going in. You need something small to help out the mid and upper range otherwise it will be just pretty much bass. Look into some 5.25" speakers in order to get better quality. I would use the 4ch to run the 6x9's and a set of 5.25" components. Then I would use the monoblock to power the sub. I would also grab a high-output alternator to provide some extra juice, because those amps are going to draw alot of power when they start producing... (I tend to go overkill on alot of things, so take everything I say with a grain of salt...) At the very least, I would snatch of some 5.25" coaxials and run them off the 4ch amp along with the 6x9's. This would give you the best sound quality at a resonable price. You could also add the sub and monoblock amp to the mix in order to get the low-range that you want. If you don't want to go out and find any additional speakers, then use the 4ch amp and run it as a 2ch and power the 6x9's and the sub.
05-04-2007, 12:08 AM | #9 |
the green machine
that last one was what i was planning on
what i might do is just put in my deck and new amp and save the sub for later, maybe get another amp and some 525's at the same time
05-04-2007, 01:23 AM | #10 |
>130dB Moderator
Yeah, for now, just go with the deck, 4ch amp, and the 6x9's. Wait until you have a little more money, then get the 5.25" speakers. You'll be much happier, I promise.
05-04-2007, 08:28 PM | #11 | |
If it's a matter of cost, I think i can help you there. PM Sent
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 05-04-2007 at 08:45 PM. |
