Old 05-03-2007, 11:05 PM   #1
bodyman9174
This should work right???
I'm only going to have heat in my truck on a switch to cut the blower on. So what I did was cut off the side of the AC box. Put some screws to hold the door close and fiberglassed it. Going to cover the one hole up. I should get heat from this right.
And the other pic is just how my truck sit as of tonight .
Thanks JAY
Cars i have done
bodyman9174 is offline   Reply With Quote
Old 05-04-2007, 07:41 PM   #2
53lowdown
Junior Member
53lowdown's Avatar
Re: This should work right???
hmm.. you mean the big part of the box part is just for AC?
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 05-04-2007, 09:14 PM   #3
JimKshortstep4x4
Bodyman9174,
What you have set up will work after you close the last hole.
Are you doing anything on the inside air/outside air system? If your flapper door and inside door is closed, you will not get much air flow.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-04-2007, 09:28 PM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
i couldve sworn the heater rad that the water goes into is in the big part that you cut off, since thats where the hoses run into
looks like a nice little mustang sittin there to, and did you buy youre tires with the whitewalls that wide or did you sand them?
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-04-2007, 09:44 PM   #5
jamie72
jamie72's Avatar
i would think you need a heater core to get heat.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-04-2007, 10:05 PM   #6
Sammy
I studied this idea at first last month. I toyed with the same idea. Finally in the end I was concerned about it not working properly. My remedy, was I found on e-bay, a A/c delete cover that mounted over both the heater & the A/c. rather pricy I believe it was just over $100. But the install went well & it done away with that huge A/c sticking out of the firewall which was my intent along with keeping heat too. Haven't cranked it yet to see how well it works.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-04-2007, 10:14 PM   #7
GREASEMONKEY72
heater core, thats what its called.. but thats what ment in my post, because looking at your pic, you cut the heater core off so how are you gona get the heat now?
-steven
Alte Seele S.S.
Old 05-05-2007, 12:58 AM   #8
bodyman9174
The heater core is there. See the 2 brass ends. Its inside the cab.I was thinking about the AC delete box to . But IF this works it nice and small. And yup going to cover up the other hole. On the inside I'm going to have to make something up. I'm going to come off the box and run the duct up to the dash. All I need is defrost.. U can see the heater core in the pic. I think this will work. Will find soon I hope
The mustang is ok doing for someone. Had to put in the torx boxes(what a pain in the butt that was), and new floor boards.than it will be gone for awhile for a cage and fit the motor in(460) than back to me for 1/4's ,doors,fenders, and paint. Fun Fun
JAY
Cars i have done
