Old 12-02-2002, 05:22 PM   #1
Yukon Jack
Yukon Jack's Avatar
Pics of engine progress
Here is a pic of the new rocker arms and springs we installed this weekend.
And here's a pic of the gear drive.
And finally, a pic of the engine, just about finished.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-02-2002, 05:40 PM   #2
Crank
Crank's Avatar
Damn, looks exceptional. I think it'll be a nice addition to your truck. Can maybe you or someone else explain to me the difference between a noise and quiet gear drive or is it just something you can't discribe, just a sound? Looks nice, keep up the good work.
Brandon
Crank is offline   Reply With Quote
Old 12-02-2002, 05:45 PM   #3
Yukon Jack
Yukon Jack's Avatar
From what I have been told, the quiet are still noticeable. The noisy ones are annoying to some, guess it's a personal preference thing. The ones I have heard make you think a blower resides under the hood. The difference is how the gears are cut. The noisy are straight cut gears.
I wanted noisy - that will match the rest of the truck . . . noisy!
Old 12-02-2002, 05:58 PM   #4
Crank
Crank's Avatar
Oh, okay I guess. It's just a preference thing then. I'd prolly like the quiet, that way I could hear the thump of the cam better. lol. Is that gear drive a wet or dry system? I was just wondering. Again nice motor. Looks better than that greasy goblin you had before.
Brandon
Old 12-02-2002, 06:03 PM   #5
>X<
registered IWATA user
>X<'s Avatar
stop posting pics of your motor! makes mine look plane. what distributor/ignition system are you running? nice motor. sean
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black
-'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end.
-01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny.
Take off that Von Dutch hat before i stab you with a 000 Mack.
>X< is offline   Reply With Quote
Old 12-02-2002, 06:09 PM   #6
Crank
Crank's Avatar
Accel maybe???
Old 12-02-2002, 06:10 PM   #7
Yukon Jack
Yukon Jack's Avatar
As I understand it, there are a couple small holes that allow oil in this area, not changed from what is there stock.
The ignition is an Accel blueprint HEI distributor and I bought an MSD coil, the one that can stand up to more vibration. I just couldn't afford to go with an MSD distributor. Budget has to stop ya somewhere.
Old 12-02-2002, 06:11 PM   #8
WOLFMAN
NOISE !!!!!!!!
Hay, I had a gear drive on a "D" stroked 400 in a 79 z28 I had. LOVE THAT SOUND!!! Mine was the quiter cut though, You could only hear mine from the frontand side, sounded like a blower. I had 2.5" flowmasters dumping at the rear so that's all you could hear.
Looks great, keep up the good work, it'll be worth it in the end.
68 GMC short fleetside / 350 LT! sb. / 350turbo w/shift kitand / 3:73 posi./ps/pdb/ac/front sway bar/15x8 rallys/"PORSCHE RED" w/ black tuck-n-rolled interior.
86 Chevy short fleetside w/ 406sb /400turbo w/ shift kit 2500 stall / cowl hood
WOLFMAN is offline   Reply With Quote
Old 12-02-2002, 06:19 PM   #9
SoCal71K20
Looking real good,Yukon Jack.It's always cool to build yer own.
I'm finally getting around to installing my rear shackle flip on my
71 3/4 ton pickup.I got a question for you.Do you know the best
way to get around rear axle getting closer to front of fender wells
after shackle flip install.Keep up the good work.
SoCal71K20 is offline   Reply With Quote
Old 12-02-2002, 06:29 PM   #10
Yukon Jack
Yukon Jack's Avatar
Offroad Design sells a 1" block that is drilled to offset the axle one inch, forward or back. That should be a good way - other option, get a flatbed, then you will never know the difference :p
Old 12-02-2002, 06:42 PM   #11
wrathchild
LIKE 'EM BIG AND TOPLESS
wrathchild's Avatar
YUKON.....
Long time no chat..that engine is lookin sweet!! Could ya tell me about them valve covers..them are really nice looking..gear drives are cool ..had a noisy pete jackson in a 350 I had..will prolly opt for a quiet one in the '70 K5 tho...
again..engine looks great
later.....wrath
wrathchild is offline   Reply With Quote
Old 12-02-2002, 07:53 PM   #12
71k5
The engine is looking great! Just wondering what youare using to pre-lube everything?
71k5 is offline   Reply With Quote
Old 12-02-2002, 09:05 PM   #13
racedvl
racedvl's Avatar
Looking awesome!!! I still think it would look even better under the hood of my truck!!!
racedvl is offline   Reply With Quote
Old 12-02-2002, 09:13 PM   #14
matt_field
matt_field's Avatar
what kind of gear drive is that? pete jacson?
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 12-02-2002, 10:49 PM   #15
Mike C
Mike C's Avatar
Nice Mark, I KNOW your glad it's painted now!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-02-2002, 11:22 PM   #16
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Hey Yukon, love m valve covers on u niceclean 454,better than I like them on my dirty 454, wanna swap???
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 12-03-2002, 12:04 AM   #17
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Beware the Accel dist. I got 2 bad ones in a row. The guy at the speed shop then tells me 6 out of 10 are bad. I got my $ back, went to the local Chevy dealer and bought a new GM one for $30 more. Just my 2c. Good Luck.
Motor looks GREAT
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-03-2002, 01:04 AM   #18
Yukon Jack
Yukon Jack's Avatar
Wrathchild - I got the valve covers after Mike C suggested them. I got them from Scroggin Dickey for $98 for the pair. Last time I checked they were down to $90! The are aluminum and seem awesome. Mike C has a pair also.
matt_field, it's a Pete Jackson gear drive.
chevy2racr - I better hold on the the valve cover's, but I know where you can get a heck of a deal on them!
Mike C - thanks for all you encouragement to get me to paint it - to think I was gonna just leave it unpainted. What was I thinking.
1970 CST Short Wide, thanks for the heads up. I sure hope I luck out, I don't need any problems!
Just got in from getting the timing cover cleaned up. Acetone is your friend, I scraped for 45 minutes before hitting the silicone goo with the Acetone, melted it off real good.
Old 12-03-2002, 01:17 AM   #19
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
Nice looking engine, I especially like the gear drive!!
That sure would look nice under my hood!!
Hey a man can dream......
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 12-03-2002, 10:59 AM   #20
1970 CST Short Wide
Senior Moment
You'll know if the dist is bad when you cant get any advance out of it. It will work then not work, something with the moduale they tell me. When they work its great, you know the rest.
Good Luck
Keep us posted when that thing makes fire. I want your opinion on how big a differance you feel from the Small Block to the BIG BLOCK.
Damn thats a Pretty Motor
Pittsburg Ca
94565
