Two piece Drop shackles
I have searched for these and can not find them. I saw a '87 swb at the gas station a couple weeks ago with the perfect drop I want to put in my '83 swb. I talked to the guy and he knew very little about the components used. It looked like spindles in the front and a two piece rear shackle that DID NOT require notching the cross member. It moved the eye of the spring back behind the cross member. He thought they were called easy ride or soft ride. All he really knew is they were spendy. I would rather used these then cut up a clean box. We don't see too many in MN. Any help would be great. Thanks
Flat Black, & Chrome!
Re: Two piece Drop shackles
You can do a flip kit without notching the frame or bed, or you can do shackles and hangers.
shackles and hangers should get you a ~4" drop while a flip kit should do ya for ~5" Either of those options are for the rear.
Did they look something like this?
![]() They are called velvet ride shackles, see link below.. http://dan.prxy.org/Truck/Aftermarke...lvet-Ride.html
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
How do they attain this smoother ride that they claim ? Is the lower part of it made of rubber ? Is that safe ?
![]() The black Diamond (square standing on its point) is all rubber, so it gives a bit before the leaf spring has to flex. Smoother yes, last long no.. I cant imagine it would.
That is exactly what I was looking for. Thank you. I am looking to level the truck so the rear only needs to come down about 2 in.
Chris
umm would thoose even be considered drop shackles?
I mean looks to me like they are the same length as stockers would be.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Nope, I believe they are just replacement shackles.. no drop.
Chris
I was thinking the same thing. That's why i asked lol.
I've heard that they lower the back about 1 inch or so, maybe 2. I did a little research and as far as I know they aren't being manufactured anymore.
The only thing I couls come up with is a Mr. Gasket part number from summit racing. The did not have a picture and I cannot find them in the online version of the Mr. Gasket catalog.
Who sells drop leaf springs for the '73-87 Chevs?
Happy to be here
![]() Join Date: Mar 2000
Check with Summit Racing.
#15 |
Insert Witty Text Here
I bought mine from http://www.performancesuspension.com.
http://www.performancesuspension.com/trucklowering.htm Slonaker |
| Bookmarks |
