Old 09-23-2005, 09:06 AM   #1
jfw867
Casting #`s
I have a 1972 C/10 with 402 big block. The Vin# is CCE142S172244. The casting number or the number I found stamped on a machined surface on the front passenger side of the block is T0310TLM. Is there any way for me to tell from these numbers if this is the origional 402. The sticker in the glove box says 400. Any help on either of these numbers will be greatly appreciated. I am taking the truck to an auto show in the morning and would like to be able to tell what I have. THanks, Joe Watson
jfw867 is offline   Reply With Quote
Old 09-23-2005, 10:01 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
block suffix code reads:
1972
truck
402
210 HP
TH 400 trans
L-47 RPO
according to nasty z-28 site
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-23-2005, 05:25 PM   #3
jfw867
What does L-47 RPO mean? THanks, Joe Watson
Old 09-23-2005, 05:28 PM   #4
Blazer1970
Blazer1970's Avatar
L47 is the code that GM used to identify the motor that is in the truck. It should appear next to the engine option where it appears on the sticker on the glove box door.
Blazer1970 is offline   Reply With Quote
Old 09-23-2005, 07:02 PM   #5
jfw867
How can I tell if this is the origional engine? THanks, Joe
Old 09-23-2005, 08:49 PM   #6
Big Block
Big Block
Big Block's Avatar
T0310TLM T=Tonawanda Plant 03= month built (March) 10=day built TLM=8cly, 400cid, 210 hp, 8.5:1 comp ratio, 4BC carb, TH Trans. TLM on your block shows it is for a 72 chevy truck. If your engine appears stock with all the original equipment and is equiped with a 400 trans it most likely is. B.B.
Big Block is offline   Reply With Quote
Old 09-24-2005, 08:15 AM   #7
Blazer1970
Blazer1970's Avatar
You can't be 100% sure since VINs were not stamped on truck engines until '73. It is VERY likely that it is the original engine though as long as you have the L47 listed on your glove box sticker.
Old 09-24-2005, 03:37 PM   #8
jfw867
Thanks, I was told by several people the same thing. I believe it is origional.
Joe
Old 09-24-2005, 04:08 PM   #9
FormerMember
210hp for a 402?
Whoa.
I need to do something to liven this motor up a bit then.
FormerMember is offline   Reply With Quote
Old 05-06-2007, 11:33 PM   #10
albertarose
albertarose's Avatar
Re: Casting #`s
My L 47 396 is fairly stock and hauls ass! ..soon..It might help too that truck took an 800 lb diet.. about that engine I like it ..its internally ballanced so be for worned its expensive to rebuil one ,,this one has 40 thou. on it and feels barely broken in ..it got bored 20 over high nines compression re curved again...distributor . hyd lifters oval port truck heads built for unleaded .mild RV crane cam edl intake 750 carb im trying soon I always ran a little 600cfm for economy..the truck is very quick and can still tow a big trailer 3 times as heavy as it is . then trailer drives truck not you.. just cause its a 2 bolt truck block dont let that fool you the bottom end can handle lots..just remember it was the one of the first crate bigblocks ! always an niceoption and a hell of a short cut if you cant be happy with 400 to 600 horses without juice
albertarose is offline   Reply With Quote
