05-07-2007, 08:36 PM | #1 |
How best to weld stake pockets?
One of my middle stake pockets is detaching from the inner bed due to heavy use. Here's a pic;
I have never done any welding,only sweating pipes.What do I need to do to get a very strong weld on this? Thanks-Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
05-07-2007, 08:54 PM | #2 |
Re: How best to weld stake pockets?
I would drill out the remaining spot welds, grind the metal clean, spray some weld thru primer and drill some 3/8" holes where the spot welds were and plug weld it back in place. Just my suggestion.
05-08-2007, 01:06 AM | #3 |
Hey thanks. I may just take it in and have a pro do it,but I wanted some ideas anyway. Always did want to get a welder but I don't know squat about the subject.-Brian
05-08-2007, 01:35 AM | #4 |
Glad I could help. That would be good practice.
05-08-2007, 03:26 AM | #5 |
~Rest In Peace~
take a welding class at jr college on weekends
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-08-2007, 10:38 AM | #6 |
I was going to suggest the exact same thing.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
05-08-2007, 01:15 PM | #7 |
Thanks guys,but at this stage in life I don't think I'll be going to college to fix a stake-pocket! Probly just pay the man.LOL
I know they rent welders at one of the Home Depots around here.Maybe I'll practice on some scrap and then do what Aaron says. Thx again. Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 05-08-2007 at 01:18 PM. |
