Old 12-03-2002, 06:49 PM   #1
smithjp1
smithjp1's Avatar
Can a 2wd frame work on 4wd?
Is there a difference in frames from a 68 swb 2wd vs. a 68 swb4wd other than suspension
Can I use the 2wd frame on my 4x4
Thanks for all the help
smithjp1 is offline   Reply With Quote
Old 12-03-2002, 06:55 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I believe they are different. Obvious reasons are the spring shackles on the front, but those could be added. You would want to find one with a leaf set up in the rear. The experts can give you a better answer. I would think going with a 73 up frame would be better. You will need to take a couple inches out of the overall length, but it is not a bad mod. Mudder67 did this to his.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
