Quick question regarding CPP brake booster
Question- On the CPP brake booster is there a return spring? The brakes work great but the brake pedal just seems to stay semi-engaged. I am thinking either im missing a return spring or maybe the vacuum supply is not strong enough to pull the pedal back out. Maybe I need a vacuum canister? Do you have a vacuum canister?
Yellow truck club
Re: Cal- Quick question regarding brake booster
I konw mine has the orginal return spring still on it..
Brian ..
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() 59 Chev Apache ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#3 | |
Re: Quick question regarding CPP brake booster
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
haha thats funny- how/where did you mount the spring?
When I get home tonight I'll take a picture and post it.
Now that is totally AMAZING. I am experiencing all of the above Problems as well.
Here's the picture. It's not high tech but it works.
thats pretty much exactly where I just mounted mine- on a side note- there should be an actual mounting point for that brake switch any reason you mounted it where you did ?
I mounted under the cab to keep it off the fire wall. I also made the switch adjustable by cutting the arm in half and drilling a hole then bolting them together.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 05-11-2007 at 02:30 AM. |
| Bookmarks |
