Old 05-07-2007, 07:25 PM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Bolt plates to hold doors on are stripped!.. Now what??
How can I fix completely stipped bolt holes in those un-removeable plates in my door pillars (holds the doors on)?? is it possible to get them out without doing too much dammage?
or should I just ream them out to a bigger size..?
anyone have luck with this?
Thanks.
smoknbarrels is offline   Reply With Quote
Old 05-07-2007, 07:34 PM   #2
Primered_69
Primered_69's Avatar
Re: Bolt plates to hold doors on are stripped!.. Now what??
Can you weld a nut on the inside of the door or is there not enough room to get in?
Maybe a JB WEld or Epoxy a nut on the back side?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 05-07-2007, 07:39 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
smokn,there are several ways to repair those.You could maybe get away with reaming them but the larger bolts may cause interference.You could cut them out and replace(depends on your bodyworking skills).If you are looking for a fix that doesn't require welding you may be able to use a thread insert.You have to drill the hole and tap it then use a tool to screw an insert in.The bolt then threads into the insert.Heli-coil is probably the most well known.Someone else may have another solution or one that works better for you.The real long term fix is to cut them out and replace.One of these other methods may get you by on a driver or may be a temp fix until you do bodywork.At least this will get you a TTT
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-07-2007, 10:17 PM   #4
Sammy
I don't know if you could reach the door plates but worth a try anyway. If this works you could get buy without re-welding which you may have to, to fix it right. Remove the door from the floor vent see if you can get to the plate that way. Might reach it, but not sure how it is secured. I cut a V slot in between the floor vent and replaced one then welded a thin plate over it. Turned out decent & not all that noticeable.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-08-2007, 12:04 AM   #5
Aarons72s
Try coarse thread bolts, factory is fine thread. I tried that on my orange and white and they seemed to thread fine into the stripped holes. They seem to still hold well. Or you could tap it for the coarse thread bolts to. That would be my first 2 suggestion to try.
Aarons72s is offline   Reply With Quote
Old 05-08-2007, 12:21 AM   #6
GREASEMONKEY72
GREASEMONKEY72's Avatar
id try this first before you got into something indepth
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-08-2007, 09:14 AM   #7
Willy Prost
I haven't tried this, but what if you welded in the stripped hole (Not entirely but a few spots around the inside). Then retap the hole to the standard size and pitch as original.
Willy Prost is offline   Reply With Quote
Old 05-08-2007, 01:36 PM   #8
grayw0lf
I third this method. The fine threads can be cut for coarse threads with relative easy & plenty of strength.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-08-2007, 02:48 PM   #9
cdowns
cdowns's Avatar
you could turn the doors around and make suicide doors
Old 05-08-2007, 04:56 PM   #10
smoknbarrels
Registered Mail
, that is a fix i guess, but doesn't seem to be the direction i want to go at the moment..lol ,
so for the coarse thread bolt idea, I just simply turn a coarse thread bolt into the hole without even running a tap into it? will this actually hold the wight of the doors up?
I don't think a few spt welds in the hole would work either, wouldn't that make the steel too hard to tap and too un-even? I'd probabliy just end up breaking the tap off in the hole.
Old 05-08-2007, 05:11 PM   #11
jamis
F.A.S.T. president
jamis's Avatar
Use heli-coils or thread-serts. Thread-serts are better for thinner material but will work there as well.
I had to use heli-coils on the cab side of the door hinge. Just remember to cut the heli-coil insert to fit the depht, then snap the tip off after you install it. A lot of peeps dont know that and put the full length in and when they run the bolt in it damages the heli-coil.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 05-08-2007, 05:53 PM   #12
jaros44sr
jaros44sr's Avatar
Tap it to course thread first, sounds like the easiest way. You could always add some thread lock solution...jmho
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-08-2007, 09:16 PM   #13
Aarons72s
I was able to just force the coarse theread bolts thru the stock holes without a tap, those plates are made of a soft steel. But if you got a tap or want to tap it then by all measns do it. Probably the better way to do it but the other way worked for me in a pinch.
Old 05-08-2007, 10:05 PM   #14
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Coarse threads are stronger than fine. Coat them with red threadlock and just run them on in slow and easy, so as not to heat them up and chance breaking one. When tight let sit for an hour or so, then you can get on with life again
Just be prepared for whoever takes them out having a horrid time. Practice up that 'I had no idea" face.
Good luck- let us know?
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 05-09-2007, 11:05 AM   #15
Shock_Me
Shock_Me's Avatar
At least you still have something to thread. One of mine broke the captive nut off inside. I guess I'll have to cut the bolt to get the hinge off.
Shock_Me is offline   Reply With Quote
Old 05-09-2007, 12:55 PM   #16
smoknbarrels
Registered Mail
yea, the plate looks to have pretty soft metal, as 2/3'rds of the holes are stripped. I know if i try to just freash'n up the fine threads with the same size tap, I'm sure they'll just cross thread.
I'll give the coarse thread tap a go... should I go slightly oversize? or not nessasary?
Old 05-09-2007, 02:19 PM   #17
Aarons72s
Same size bolt but coarse thread and you will be fine. That worked for me.
Old 05-10-2007, 10:29 PM   #18
72BLUZ
72BLUZ's Avatar
Those Inserts Are Called Helicoils. And They Are Sold At Any Parts Store Or Body Supply Shops. Or Check You Local Body Shop
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 05-10-2007, 11:34 PM   #19
70C10Toejam
Hellasick
70C10Toejam's Avatar
I say go for the suicide doors.
or do the General Lee and weld the doors completly shut.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
