will this work??
Hey all I bought a 1988 GMC yesterday really cheap. Pretty much just a work truck till I get done with my 71. My question is will the wireing,brain box,TBI set up, steering column,seat belts, seat, work in the 71. U all think it would be a good switch over? Or leave the the 71 carbed and with all the orig stuff
and keep the 88 for the winter? JAY
Cars i have done |
Re: will this work??
I am doing almost the same swap only with the tbi just to get the extra gas mileage and adjust ability. haven't started fitting stuff yet but i will be starting soon. carbed is cool too but the gas bill isint so cool.
Column would be the hardest due to the fact that it is a thicker column.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
if you switch over to TBI you will need the fuel lines, pump, and more than likely the tank. (not exact PSI) the TBI runs off 16PSI and the carb only runs off of 4-7 PSI. also if you switch the brain the best way to do it is with a new aftermarket wiring harness to cut out things you wont be running that will give your engine bad readings.
if you can get all you need then it is a good swap.
your like a prize mouth bass, i dont know weather to eat you or mount you. 1978 chevy stepside, 2002 dodge crew cab AMSOIL DEALER |
hey Spray-Bomb u have any pics of it? How hard was it to switch over. Done really seem to hard to do.
And about the tank I just order the one that goes under the bed. I could use a inline fuel pump right?
Cars i have done |
you can use an inline one as long as the PSI is right but id back it up with an inline fuel pressure guage.
Install a blazer tank, and the sending unit from a later fuel injected model (88-91) and that will give you in tank fuel pump that you need.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
