The Older Generation
Detroit Locker or No?
This is the rear axle from a 1972 C-20. I Would like to know if this is a locker or not. I don't know what to look for....Hope you can tell from the pictures. I finally found the ratio, it is stamped on the inside end of the pinion shaft, 41:10 as shown in the pic. That would be a 4.10:1, could I be lucky enough to have a locker too??? Thanks for any help you can offer. LockDoc
Re: Detroit Locker or No?
I would say no. As you can see the spider gears that would be replaced by the detroit.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
Thanks Dave. What would you see where the spider gears are if it was a Detroit?.. ![]() LockDoc
#4 | |
![]() That dark mark is just a grease smear, but you get the idea ![]() just smooth metal, you might also see a spring above the smooth metal. but as long as you don't see gears, you're good.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Thanks Adam, looks like some kind of smooth disk or gear case in there. LockDoc
