Old 05-11-2007, 10:54 PM   #4
crossy
Oh,you can't buy that new
crossy's Avatar
Re: Need help ppunching out ignition cylinder
Once you have the steering wheel and lock plate pulled, there is a slot that you insert a flat blade screw driver into. If the truck has never had the lock cylinder changed, there is a thin piece of pot metal that you punch out. Once you punch through the metal, you will hit the release tab. Push on it, and you should be able to grab the cylinder and pull it out.
I think I'll take all the stuff i need to pull the wheel and just remove the whole cylinder. I wanted to make it a 2 minute ordeal in the field and then fix it once home, but nothing is ever that simple for me anyway.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
