BEER-Vacation in a can...
i just did the power and front disc convertion on my 69' c-10 and am having a problem with the brake pedal not returning with the vacumm hooked up to the booster, it returns fine with out the booster in play. we replaced the booster already and had no luck. the brakes work fine just the pedal does not return, how can i tell if the return spring is strong enough? i am thinking that could be a possible problem.
------------------ Kurt 94' Camaro 85'Plymouth Horizon 69' C10, 350/4spd, lwb, fleetside long box, 3.5"/5" drop, power and disc conversion early 80's Schwinn 18 spd [This message has been edited by chevyhouse (edited May 08, 2002).]
Kurt 03' Trailblazer 69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik 2000 Yamaha V-Star 1100 Custom For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics |
if its ocnnected correctly under there then it should be fine, i highly doubt it could weaken up sp much thaty it wouldnt do its job. whats the exact problem ? is it coming back up and stoping at a certain point or is the pedal rod too short and needs to be adjusted, or ?
------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham current fleet: -71 C-10 350/CH465/3.07- basketcase, #1 -90 Cavalier 2.2L sky blue, a driver -84 Z28 5.0L/700R4/3.73 daily driver -84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2 -82 purple Trans Am, project #3 *Paint is overrated* © RSS Enterprises 2000 |
the exact problem is that with the booster hooked up the brake pedal stays wherever you put it, push it in, pull it out, all the way/halfway whatever. the brakes work exactly like the pedal is positioned.
ttt-any ideas???
I had the exact same problem a while back. My problem was that the bolt and nut that goes through the pedal was binding up. I loosened the nut a little, and it worked fine.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
