Old 05-13-2007, 10:11 PM   #9
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Spindles STUCK!
Originally Posted by Rc 415 View Post
Ok, I got every ball joint off but the bottom ones on both spindles,
Sounds like you went about this the hard way. Always loosen the upper and lower ball joint nuts about 3 to 4 turns and with a jack stand under the frame letting the spring push down on the control arms whack the crap out of them as everybody else stated. The pressure from the spring helps pop them loose.
Now it sounds like you will need a fork to get the lowers broke loose.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
