Old 11-30-2002, 09:51 PM   #1
Question Guage wiring--Again
I know this has been killed alot around here but I have a confusion question. Picked up a factory guage /bezel panel to use in my truck to replace the idiot lite one. Been reviewing what's needed.
1. need to rewire the connector for the changes
2. need a different temp sender
Things I didn't find and are not sure of
1. is the oil pressure sensor the same for both idiot light & gauge or do I need to swap it out also.
2. My truck is a 70 and the guage panel came out of a 68. I noticed that if you went to buy a new dash harness they list the 67-68 as one item and the 69-72 as another item. What, if anything, is the difference and is this going to cause a problem.
My engine is the 250 I6 if that makes any difference
Old 11-30-2002, 11:15 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
The oil pressure goes to the oil guage thru a small diameter oil line. No sensor involved. You have to install a small fitting back by the distributor. I'm not sure on the differences between the years, but I swapped a buddies idiot light dash for a guage one, and all that I had to do was relocate the ground in the harness and one turn signal wire. Dark blue I think. Hope that helps, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-01-2002, 12:43 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Palf70step,
Go to GMCPauls site. He has a tech page and lists the procedure step by step with a schematic.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-01-2002, 01:19 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
red71cheyenne, you only had to move 2 wires!? When i slapped a guage panel into a light panel (not knowing the harnesses were differant) i had a whole bunch of lights not work properly, and my fuel guage fried after spinning around like on a cartoon or something. Did EVERYTHING work after just 2 wires being moved?
Old 12-01-2002, 01:29 AM   #5
red71cheyenne
Back in the sticks
Those are the only two I remember. It might have been more, but those are the only two I remember. I just went off the schematic in my haynes manual. It didn't take very long, I remember that. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-04-2002, 12:03 AM   #6
Sammy
Just wanted to try to speculate an answer of your question in reference to the differances in the older dash panel's. I believe the older ones had provisions for manual chokes and the 69 and newer had automatic chokes which counts for an additional hole in the panel. Is this correct??
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-04-2002, 08:55 AM   #7
70c10
67-72 Addict!
70c10's Avatar
69 and newer do NOT have the choke hole. You are correct!
Jim
Old 12-04-2002, 06:42 PM   #8
I knew about the choke hole but I was wondering why the wiring harnesses were listed as different numbers. I was curious if there was something different in the actual wiring between a guage dasy for 67-68 and one for 69-72?
Old 12-04-2002, 08:22 PM   #9
john
member #16
john's Avatar
Is the wiper switch on the opposite side of the cluster?
john is offline   Reply With Quote
