Dirt inside valve cover
So after leaving my truck over winter, I found a plug or sensor on my valve cover fell out. I felt inside and theres alot of dirt and grime inside the valve cover. (sorry the pic is alittle dark, its at the very left side of the valve cover)
Im pretty new at this so can I just remove the valve cover, clean all the gunk out, put a new cork gasket on and bam shes good to go? Is there any info I should know about before doing this? thats more like 2 or 3 questions but they are all about the same thing ![]() |
68 C10 Longbed
![]() Join Date: Sep 2006
Re: Dirt inside valve cover
Yep, thats all you have to do. Remove covers, spray off with air and wipe off whats under them (rockers,etc.), new gaskets and reinstall valve covers. Should work just fine.
It's the air up here
I would clean it then run it for a minute, and change oil and filter.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
I would only change the oil and not worry to much about the grime and sludge. once you mess with it, it will get all loose and starting to circulate in your engine which can start to plug up your oil gallys and then you got a whole nother mess. There is a saying...If you see lying dog sleeping, let him sleep.
There is no replacement for displacement! |
GEARHEAD
I say pull it off clean it, replace the gaskets and change the oil not long after just like eedgell said.
RJ22 |
#6 | |
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Thanks for the info guys, I took my valve covers over to my mechanic to ask him how to clean them properly and he let me use his urethane? tank to clean them, which worked awesome. I got all the gunk out of the senser hole/baffle (came out in nickel sized chunks) and at the sametime found out I have nice stainless steel valve covers.
Now the only other question I have is, how hard do I tighten the valve covers back on??? ![]() |
GEARHEAD
I will get ya the exact torque spec but, personally I never use it here...
![]() I go by feel here just tightening to pressure making sure not to distort the valve cover itself. Looks like 3 ft. ibs. Here's a link to all the torque specs for ya. ![]() TORQUE SPEC'S SBC RJ22 ![]()
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! ![]() Last edited by RACINJASON22; 05-15-2007 at 08:33 PM. |
Thanks for the info dude, that link comes in real handy
